Results 1 to 10 of 30
Thread: HELP!! Misfires after going lean on nitrous
    Oct 2007
    My truck is running again since I melted 6 spark plugs and broke the flexplate at the sar meet and I am having some misfiring and popping from the exhuast. No diagnostic codes are being thrown. I have already changed plugs, wires and now need some ideas on what to try next. After running the new plugs for a few miles I pulled them out again to check them and found that 7 of them have light brown electrodes but 1 has a white tip and the porcelain is bright white while the others brown. Could it be a failing injector, coil or 02 sensor? Also my afr went from 13.0 before the lean condition to 14.0 WOT now that it's running again on the same tune. My only plans so far include having my buddy log it on HP tuners and doing a compression test.
    9 sec truck club
    Dude, sounds like you were spraying it and now the engine is a goner.
    I gaggree (per Vince Young). It's probably not ignition or that plug would be fouled.
    Feb 2009
    mississippi
    no fuel most likely
    04 1500 5.3L custom hp tuners tune by myself don have a pic of it yet so hear is my old 01 chevy 5.3 460hp 13.669 @ 116
    Oct 2007
    Don't think the engine is a goner cause it has lots of balls even though it's missing. if the plug is clean does it mean that it's not lighting or would the injector not be working?
    9 sec truck club
    Feb 2009
    mississippi
    if it wasn't hittin it would be fouled
    Your cylinder walls are trashed, most likely. You're getting oil past the rings.
    Feb 2009
    mississippi
    he sead his plug was clean
    ff_jeff Guest
    maybe an air leak. Check all of your intake for possible leak. If any air gets passed the MAF it will run lean. If you have to take off all your intake couplings and put them back on tighter. See if that helps. dont spray is unil you fix the af ratio problem. Also check vacuum hoses, and ports.
    DFW
    Sounds like it's sucking coolant in the cylinder.
    Red 98 SUX2BU SS 11.04@121.69 with bolt ons RIP
    2003 White Diamond Escalade ESV AWD Long tubes, Comp cam 224/230 .581" .591" 114 lsa w/ dual springs, CAI, pulley, 05' E-fans, dual cut outs, Yank PT3200, Transgo shift kit, Billet 4th gear servo, Vette 2nd gear servo 8.976@77.16 MPH
