Results 1 to 10 of 26
Thread: my 2005 silverado ls1 build
    Jun 2006
    Well it is now time for me to start the project i have been dreaming of since i was 14 years old. I finally stumbled across a deal that i couldn't pass up. here is a quick overview of the project... but first i would like to let you guys know... this project is my daily driver and will be seeing a good amount of track time.... but more driving around campus... i go to Texas Tech!!! Wreck EM'! anyways back to the project...
    Vehicle: 2005 Silverado 1500, Regular Cab, Short Bed.
    Current Engine: 4.3L v6
    Current Modifications: McGaughy's 4/6 Spindle Drop, Painted stock rims, air intake and exhaust.
    _______________
    Swap information:
    all below parts are out of a 2002 Ram Air T/A with only 36,000 miles on it.
    Parts already acquired:
    • 2002 ls1... complete from intake manifold to cat's
    • 4l60E automatic transmission
    • wiring harness
    • AC Condensor
    • Stock T/A Air box
    • Misc Hard Lines and soft hoses
    • computer
    • almost anything you would see if you opened the hood of a stock ram air T/A
    now i need some major input on what i still need... i thought i knew everything and turned out when i was ready... i didn't lol. :bang:
    So far what i can think of are the below items
    • long tubes
    • frame mounts.... the engine mounts are still on the engine
    • x pipe
    • im not sure on the whole DBW or DBC throttle body situation
    • upgraded fuel pump?
    • fuel lines?
    • air intake set up
    • oil cooler
    • truck tranny pan
    • truck pick up tube
    • Vette fuel filter/regulator
    I know there are things i am still forgetting.. please chime in.
    a few questions:
    • With all the wiring harness situation.. should i use the T/A harness or take a truck harness and cut-and-wire to the injectors?
    • can i run it on the f-body tune until i can afford a nice dyno tune? or would that be asking for trouble?!
    • what throttle body type do i need to use in order for my cruise control...etc to work...?
    and I am sure i still have more questions... i will update as they come to mind.
    The following are pics of the truck the engine is going into... and also the engine and transmission
    thanks for the help! and i cant wait to start the ball rolling on the dirty work!
    Preston
    05 Chevy Silverado. Regular cab, short bed.
    -4.3L
    - Sung Top tonneau bed cover.
    imco custom dual exhaust,
    custom air intake,
    ls1 build in progress..
    damn preston you got your work cutout for you son!
    Im not sure about running on the fbody tune..
    Jun 2006
    haha thanks man... i got an insane deal and couldnt pass it up.... any input on the questions?
    -4.3L
    custom air intake,
    Apr 2006
    Bellevue, Nebraska
    I'm not smart on things like this,yet, But I don't see the reason you couldn't run the Fbody tune. If you're only using the drivetrain components from the TA with the ECM from the TA you should be good. The engine won't know that it's in a truck.
    That's just my theory.
    you will need to get someone to switch the VIN in the PCM to match your truck, or a truck the same year as your's so that it will pass emissions testing. The rules state you can't put an older engine in a newer vehicle in an emissions county in Texas. The engine should pass a sniffer test without issue if you end up having to do one.
    Jun 2006
    ya i was thinking.... hey just rip everything out and replace it with the ta stuff.... then i should be good right? just trying to make sure i have everything before i start
    -4.3L
    custom air intake,
    btw paint those center caps black.. make it look a whole lot better
    Jun 2006
    im gonna get the rims powdercoated first..
    -4.3L
    custom air intake,
    Jun 2006
    this is what i would do. find the correct frame mounts and the motor mounts.
    second i would find a correct year truck harness
    3rd using that trans it doesnt have the black box or the longer gear selector shaft that trucks use
    i would find correct harness and swap the pigtails onto it so you can always use car injectors.
    if you have hte Fbody powersteering high pressure line it will screw right into the truck rack. i did the same.
    the car pcm is going to be different then a 05 truck pcm. they have different color plugs and connectors
    a car tune would fire it but it wont control everything properly as for guages and etc.
    correct harness... as in an 05 v8 harness? and your saying dont use the f body tranny?
    -4.3L
    custom air intake,
    Jun 2006
    well my current 60 is about to take a ****... so i was gonna run that until i can get the f-body 60 rebuilt... is that possible?
    -4.3L
    custom air intake,
