Originally Posted by
RedHeartbeat
There are about 4 different ones you can get, red, blue, green or brown. I'm thinking the blue was the thickest one for the 6.0L truck engine. I'm probably wrong though.
im going with red ,i had the same problem ,gm says red is the thickest..i put it in and fine .these orings need to be adressed,its a constant problem and alot of trouble for a crucial part.but i think he said he checked it ,although it could be wrong 1 .
