Results 1 to 10 of 11
Thread: what shocks are you guys running?
    Mar 2007
    Rockwall, TX
    finally got the truck running and am now looking for some suspension.
    what is a good cheap adjustable shock i can use on the 79?
    i am going to install some 2" lowering shackles now, and maybe go a bit lower in the future.
    Slimsilverado Guest
    on my 82 i have KYB and on my 01 i have edelbrock ias set up for lowered suspension
    Mar 2007
    Rockwall, TX
    will the kyb's adjust?
    i want some i can adjust for the track
    Slimsilverado Guest
    If you want adjustable then try QA1 and get you check book out, those are the only adjustable shocks i know of....
    Check out the Rancho 9000s. I think that's what BlueCajun5.3 runs with his suspension.
    Mar 2007
    Rockwall, TX
    yeah, i knew the qa1's would be expensive, was hoping there was another option.
    i will check out the ranchos.
    thanks
    Aug 2003
    Spring, TX
    belltech has some new lowering/lifting shocks and some coilover shocks that you might want to take a look at.
    they probably are cheaper thant he QA1's.
    -leo-
    2009 Silverado CC - 6.0L L76|6l80e|3.42s|4/7 drop w/ helper bags
    01 silverado ecsb - (RIP 04/2009)
    Jul 2007
    Colleyville, Tx
    i have beltech nitro-active shocks all around
    Sep 2004
    Breaux Bridge, LA
    werd on the ranchos
    11' Sierra 6.2 NHT
    14.46@91 Stock
    89' Mustang LSX
    10.35@130 pump gas LQ4
    Knothead Racing
    Sep 2006
    Coon Rapids, MN
    Edlebrock IAS
    04 Grand Prix GTP
    03 Z71 wanting a Turbo ,Stall, and Tune BAD
    THE SURGEON GENERAL SAYS NOTHING ABOUT SMOKIN A FORD
