Sea Foam Additive!
All I can say is dam! That sh*t is good. As you all know I had an oil bath in the intake again and got it all cleaned out again. The motor had burned some of the oil, so I used the Sea foam in a tank of gas and man it smoothed out the motor to where you can't even feel it idling. This motor has a 220/220 .581//.581 on a 115 cam so almost no lope. The motor sounds stock at idle.
I like it!
Good stuff.
Jamest
12 Sec. Club! SOLD
SOLD***
