Results 1 to 10 of 33
Thread: Sea Foam Additive!
    Ah, it white-smokes for a good 3-5 minutes as you slowly add the Seafoam to the vacuum line. After you reconnect the line, it should stop for the most part, but I would recommend driving it pretty hard around the block to get rid of it all...
    Jan 2006
    I may need to do that to my intake as well.
    Jamest
    12 Sec. Club! SOLD
    SOLD***
