This is a common question on the board so here is a link to Hit Man X's post over on GMFullsize
http://www.gmfullsize.com/forum/showpost.p...mp;postcount=40
As mentioned in the post, pay particular attention to clearances and backlash.
The Electronic Pressure Control to vacuum modulator control device is Transgo kit 46MOD available from Oregon Performance Transmission or TransmissionCenter.net.
The most common shift kit is the Transgo 4L60E-HD2 model though they do sell a simple shift correction kit.
The Raybestos Blue Plate Special 3-4 clutch pack comes with instructions to drill a #58 hole to vent residual oil out of the input drum housing, from behind the piston that actuates the 3-4 clutch pack.
http://i47.photobucket.com/albums/f197/red...t/5-31-2007.jpg
Feel free to add to this post any good information or part numbers.
Good items to have for a stock+ rebuild...
Transtar PNs...
Transgo 4L60E-HD2 kit
Corvette 1-2 and 4th servos if stock converter and billet servos if 3000+ rpm stall converter
Aluminum forward accumulator piston
Aluminum 1-2 and 3-4 accumulator pistons
Complete gasket/seal kit for appropriate year model transmission
new transmission filter. Make sure to measure the depth of your pan to get the correct one.
three bonded piston seals
New valve body spacer plate
"Beast" sunshell
if 2nd gear was slipping get a new or rebuilt reverse drum
New Borg/Warner clutches and band
New steels
Here's what I'll order for someone that already has the shift kit and Corvette servos...
Master kit 4L60E (W/ PISTONS) DEEP PAN............................................... ................ 97-03........ 74008EC
includes clutches, steels, filter, gasket and seal kit, metal clad seals and 2nd band
Reverse Input Drum (No Check Ball) (Large Feed Hole)............................................. .. 3/87-Up..... 74556B
Plate, Valve Body To Case Separator, 4L60E (Transgo)......................................... ....... 96-05...... 74747EC
Piston, Forward Clutch Accum, 4L60E (in Valve Body) Aluminum...................................... 1 93-Up... 74741G
Kit, 1-2 & 3-4 Accumulator Piston (.310” Pin Dia) (Pinless Design)............................ 1 82-Up.......... 74927K
Shell, Reaction Sun (The Beast) (incl. Special 4 Tang Washer).................................... 1 82-Up...... 74624A
