Results 1 to 10 of 12
Thread: 4.10's are in
    Jan 2005
    Humble/Houston TX
    got annoyed with my 60' times so i did the swap hoping it will help a little.
    times with 3.73's was 13.09@105.5 with a discusting 1.96 60' in OK weather. my mph says 12.6ish but my 60' says screw you! that time was spinnin the 28" hoosiers because of my sissy burnout. if i dead hooked i think i woulda broke outa my 13.00 bracket that i was in. hopefully the gears will get me lower into the 1.8 range or if im extreemly lucky a 1.799 :crosses fingers:
    i usually cut 1.88's so the 1.96 was due to traction. well see
    old mod list: H/C/I/N/E/G 408
    Have you installed some Caltracs yet? Maybe you're getting some chattering in the axle that is causing your traction issue.
    Jan 2005
    Humble/Houston TX
    <div class='quotetop'>QUOTE(RedHeartbeat &#064; May 28 2007, 10&#58;02 AM) [snapback]94942[/snapback]</div>
    Have you installed some Caltracs yet? Maybe you&#39;re getting some chattering in the axle that is causing your traction issue.
    yeah i thought about cal-tracs but they are way overpriced and i hear they make the ride worse. mine is already pretty rough. maybe ill put the spring clamps back on
    I hear you&#39;re supposed to adjust the bars for street driving and re-adjust them again at the track to snub the traction bar against the spring.
    Who helped you with the install? Was it hard?
    Jan 2005
    Humble/Houston TX
    the install was pretty easy because we swapped a rear end from a truck sitting next to mine so we didnt have to jack with shims etc... basically i kept my carrier, we swapped over the rings and pinnions, we traded shims, traded sleves and put them back in. i would have no clue how to do the shimming etc. im paying for my detroit tru-trac to be installed because it will need to be re-shimmed and the bearing pressed on.
    Jan 2007
    Hurst
    Nice choice in gear selection&#33;
    Oct 2003
    TeXas
    your going to see about 2/10&#39;s with the 4.10&#39;s over the 3.73 stewbie, good luck on your quest.
    http://i17.photobucket.com/albums/b9...5831PM-2-1.jpg <--- TimeSlip
    RCSB 5.3 N/A 12.31 full boltons,H/C,4.10s,3800 converter. SOLD
    04 GTO
    Both Tuned By: ME
    Jan 2007
    Hurst
    <div class='quotetop'>QUOTE(vv8 &#064; May 28 2007, 12&#58;34 PM) [snapback]94959[/snapback]</div>
    Thats how much of a improvement i got. I was running 10.8&#39;s in the 1/8 and with the gear change ran 10.5&#39;s
    Oct 2005
    Houston, Tx
    congrats man. thats one of the things that im wresting with 4.10s or not..too many mods not enough time.
