Page 6 of 6 FirstFirst ... 4 5 6
Results 51 to 60 of 63
Thread: Output Shaft End Play (4L60E)
    good luck. I hope it works out for you.
    Oct 2005
    Baton Rouge, LA
    <div class='quotetop'>QUOTE(RedHeartbeat &#064; Jun 9 2007, 11&#58;10 AM) [snapback]96174[/snapback]</div>
    It works&#33; The 160* t-stat helps with temps, but I need to have the radiator flushed. With this stupid Louisiana heat + humidity, I&#39;ve seen my temp gauge hit 210* after a few start/stop runs to the store. Cruising in today&#39;s 92* (53% Humidity), the temps are between 185* - 195* (depends on very long traffic lights). I&#39;m happy for now. I&#39;ll get the rad flushed sometime next week.
    Oct 2005
    Baton Rouge, LA
    Red Eagles to be on order...
    VacMod kit may be on order next month...
    Looking for a new trans pan with removable drain plug...
    Long story short, anything less than Red Eagle clutches will burn, drill out the input drum for better flow & drain of fluid for the clutches, and the vac mod kit helps by not totally relying on electronics to control pressure. Truck will be down for about a month (no EXTRA money). BTW... couldn't get better than 14.5 runs. I need a performance tune. Clearly, I don't know what I'm doing. :p
    Oh no, not again
    Oct 2005
    Baton Rouge, LA
    Oh no, not again
    yup. decided to make a track appearance since Lance (bluecajun5.3) came over from Florida. sad part is, i knew something was wrong after a few passes. lucky for me, i know a few stand-up guys that don't mind helping out when necessary. C10 got a comfy ride on an expensive, all aluminum car hauler... towed by a Big Horn Ram. Got to my house, back the truck off, and drove it toward the back of the house. I'll pull the trans sometime next week.
    Clutches ordered. I'll order the vac mod kit next week (short on EXTRA money til pay day).
