Damn the luck if it's one it becomes another. I got the heads installed and went to put coolant back in the system and it wouldn't take it. I pulled the bypass lines off the head and it helped to get some coolant up to that point. Now when I start the truck I have no flow at all through the radiator. The head gaskets were put on with the "FRONT" markings to the front of the block with the drivers side gasket turned upside down since that's the only way "FRONT" will be in the front. LOL Any suggestions like maybe a bad water pump or thermostat? Anyone ever ran into a problem like this before?
97 GMC, 2002 LS6.
1991 GMC Syclone #1428
- You may not post replies
- You may not edit your posts
