Results 1 to 7 of 7
Thread: Question about getting cruise control to work on 73-87 Chevy Trucks wi
    San Marcos Texas
    I have the 2002 Camaro setup on my LS1. It was not too difficult to set up just a bit of wiring. I had to change the switch on the turn stalk to the 4 wire switch (my vaccuum setup had 3 wires). My truck already had cruise so it had all the brake switches already in place. I can get pics but there isn't much to look at, just a box with a throttle cable and some wires pluged into it.
    Oct 2006
    <div class='quotetop'>QUOTE(GMCwantsLS1 &#064; Oct 11 2006, 02&#58;59 PM) [snapback]68874[/snapback]</div>
    I have the 2002 Camaro setup on my LS1. It was not too difficult to set up just a bit of wiring. I had to change the switch on the turn stalk to the 4 wire switch (my vaccuum setup had 3 wires). My truck already had cruise so it had all the brake switches already in place. I can get pics but there isn&#39;t much to look at, just a box with a throttle cable and some wires pluged into it.
    What all modifications had to be done to the frame on your Truck to install the LS-1? Did you notch the frame to use the stock compressor location?
    What other tips or suggestions do you have for me on this swap?
    Thanks for your help&#33;
    1994 chevy 3500 Crew Cab project. Soon to be lowered and shortened into a shortbed!
    houston
    Quote Originally Posted by GMCwantsLS1 View Post
    my 87 i guess had vacume setup since it had a rubber hose... but i have 4 wires on the cruise pigtail... thats wierd ...
    1987 5.3 4l60e Silverado - daily driver with A/C,P/W,P/L,TILT and HID projectors - also for sale @ $8,500
    A poor man buy's it twice
