Results 1 to 10 of 13
Thread: 2002 L31 350 PCM to run 97 L31
    Jul 2005
    Hey guys, I know its not a LS based engine but the 2002 PCM is 1220041 p/n out of a 2002 Chev. 2500 cargo van with the L31 Vortec 350 also controls some GEN III stuff.
    I have a 1997 RCSB 350 4l60e Hooker Comps, Ed Wright tuning L35 torque converter, marine intake with 24 lb injectors running at 62psi. My truck currently uses the 97 PCM, I am wondering on the use of the newer PCM, for dual octane tuning and the use of LS1 edit.
    1. Are the sensors off of the 2002 L31 350 going to be the same as my 1997 L31 350?
    2. I know the pinouts are different between the 2 PCM's, can I splice in the new computer into the "old" truck? I know its HARD, can it be done? I have allready spliced in the 8 24 lb/hr injectors to the stock 97 injector drivers, with no probs.
    3. I see that Tunercat now supports the 96-05 trucks(even for different sized injectors), but I have heard that the makers of LS1 Edit now have Truck Edit and they have support for the 01-05 Vortec L31 350, along with the 496 and the 4.3 v6.
    4. Has anyone heard of this?
    5. what are the highest rev limiter settings anyone has seen while using self tunes? What did the tach. read?
    6. What are your guys opinions/ comments on this?
    thankyou in advance, Ive lurked here for quite a while
    Hog
    97 GMC 2wd RCSB 5.7, s10 2700 footstall, Hooker 24621hkr LT's , 2.5" cats dual 4"pipes exit B4 pass. side tire, custom driveshaft 3.42 G80 FIPK MAF descreen GM/Mercruiser Marine intake manifold 29lb LS2(EV6) injectors Ed Wright PCM(best mod), LT4 KM 14.8@94mph 2.007 4000lbs 122mph
    Jul 2005
    Well I have the marine injection system and intake installed. I'm pig rich from my 24 lb injectors replacing the stock 19lb poppets.
    I need info on the newer PCM so I could get Allen to tune it.
    Hog
    Dallas, Tx
    Im still waiting to see some dyno results before and after before considering the Marine intake swap.
    Shane
    1996 GMC Yukon 4x4 4-Door. Bone Stock for now. Need Moneys.
    Jul 2005
    Well a 411 PCM from a 2001 L31` Vortec 350 powered Chevy fullsize van will indeed power a 1998 Vortec 350 truck.
    The 5800 rpm rev limit of the black Vortec PCM's hasnt been broken. Now if you use EFILive, HPTunerts and of course Tunercats 2 can be used to tune it, so far a 1998 Vortec 305 with twin turbos and the 411 PCM has seen 6200 rpm, this beats the black PCM's limit of 5800 rpm.
    peace
    Hog
    May 2004
    Where does everyone get 5800 from? I was able to program my 97 to 6000 and If I remember correctly it would go past 6000 with the custom made box. I still have the programmer and custom tuned chip. I'll verify this to make sure but 5800 sounds awful low but then again I'm getting older and more senile! I'll let you know what it does as soon as I find someone with another truck I can tune on. If I"m wrong, I'm wrong. LOL
    97 GMC, 2002 LS6.
    1991 GMC Syclone #1428
    May 2004
    Ok, I verified and I can tune up 4800 to 8000 RPM in 100 RPM increments on the 97 PCM. I can also tune idle 600 to 1500 RPM. The 5800 is BS.
    97 GMC, 2002 LS6.
    Jun 2009
    Benton Mo
    need info
    i have a 97 gmc with the L31 vortec but is not the stock block it is a gm crate motor... but i was wondering where can you buy the marine intake, and iam wanting to know what the pinout on a 97 computer is compared to the 98 computer... and can i run the L98 heads off of a corvette on the L31 block and intake.... i all ready know that you can run the headers off of the L98 covette. because they dont make a set of long tubes for these truck... thanks....
    Quote Originally Posted by L31redgmc View Post
    This topic is 2 1/2 years old. I think I would start a new topic with your questions.
    ff_jeff Guest
    do you know the answer?
    Dec 2004
    San Antonio, TX Area
    I have these links, the guys there have done several of these conversions. Hope it is what he is looking for.
    GM Performance :: View topic - 98 GMC Twin Turbo with 12200411 PCM--- It's Alive
    GM Performance :: View topic - Vortec L31 MARINE MANIFOLD project! Q&A
    GM Performance :: View topic - 96 0411 swap done!
    There was a member here, username PSWired that told me about this website. He also did a Gen III conversion in his OBS Z71. Came out really nice.
    "ALisSa1 Silverado"
    Scrimpin Ain't Easy
    ( . Y . )
