Page 4 of 4 FirstFirst ... 2 3 4
Results 31 to 34 of 34
Thread: crap that sucks haha
    DBYRD Guest
    ok the set of mounts i have both have 4 bolts going into the engine just like the plates do, but wtf is that braket attached to the plates, i dont have anything like that??????
    Dec 2005
    Houston,TX
    Are you talking about the cups that bolt to the mount on the crossmember
    s&p headers, custom radiator with e-fans,
    91 sub front end with billet grill and bowtie,
    autometer gauges, red and grey tweed interior, dual 2.5" flowmaster super 40, Dmh cut outs, 5"-7" drop,
    air shocks, 20" Intro twisted vistas, gaylords bed cover
    There are two types of mounts out there. There are the 4 bolt mounts that the GEN3 engine uses and then there is the 3 bolt mounts used in the GEN1 engines. The GEN1 engines used a cup, like in Jeff's picture, bolted to the engine block with 3 bolts. The engine mount was bolted to the crossmember in the GEN1 engine and the adapter plate moves the GEN3 mounting location over the crossmember. Can you take pictures of what you currently have for engine mounts?
    DBYRD Guest
    <div class='quotetop'>QUOTE(RedHeartbeat &#064; Jul 11 2006, 07&#58;30 PM) [snapback]57809[/snapback]</div>
    There are two types of mounts out there. There are the 4 bolt mounts that the GEN3 engine uses and then there is the 3 bolt mounts used in the GEN1 engines. The GEN1 engines used a cup, like in Jeff&#39;s picture, bolted to the engine block with 3 bolts. The engine mount was bolted to the crossmember in the GEN1 engine and the adapter plate moves the GEN3 mounting location over the crossmember. Can you take pictures of what you currently have for engine mounts?
    ill post em later kinda busy tonight with family bullshit haha.
