Results 1 to 10 of 52
Thread: Lots of pictures coming first time swap LQ9/5 speed going in a 92 k1500
    Dec 2008
    South Carolina
    What clutch and flywheel are ya gonna use?
    2008 GMC Sierra SLE....370ci LY6 with some goodies SOLD
    Quote Originally Posted by chvy=power View Post
    Flywheel is a sachs 1050. Didn't plan on buying a new clutch because I'm swapping in a nv4500 as soon as I find a good used one. Are the clutches for a nv3500 and nv4500 interchangeable?
    Ethan
    First & only 4th gen Ram 4x4 in the 12's NA 12.747 @ 104.07 (1.663 60')
    2012 Black SC 4x4 1500 Hemi ARH longtubes, Vararam intake, Circle-D 3000, Meziere E-water pump
    Moe's 87mm throttle body, efan, 2010 frontend swap/4.56 gears, Greene Racing tune, E-power steering pump
    Dec 2008
    South Carolina
    You have to run a LS 4.8 clutch with the 1050 flywheel....the older ones won't fit and the bolt holes are different. I ran the RAM 1550 flywheel and it will run the LS clutch or the sbc clutch. And I'm not sure if the 3500 and 4500 use the same clutch but I don't see why they would be different..
    Damn, thanks! You don't happen to have a part number for the LS 4.8 clutch do you?
    Ethan
    Dec 2008
    South Carolina
    You the man. That's the one I was seeing but was hoping there was a cheaper one lol
    Ethan
    Dec 2008
    South Carolina
    You sure the bolt holes are different on the sach 1050? My buddy did a 5.3 swap with nv3500 in a 90 k1500 and used his stock clutch with the 1050. They also put a stock one in another friends 90's model with 5.3 swap.
    Ethan
    Dec 2008
    South Carolina
    Here's the problem....the obs flywheel has standard threads. The pressure
    Plate bolts are shouldered so they center the clutch assembly on the flywheel. The nbs flywheel has dowel pins that center the pressure plate. It uses metric bolts. To use the obs clutch on a nbs flywheel you have to remove the dowel pins, and the metric bolts arent shouldered...and I believe you have to ream out the holes on the obs pressure plate for the metric bolts to go through
    It. So now what keeps everything perfectly centered? some people don't have any problems with it but Iv got too much into my build to gamble on something like that
    Dec 2008
    South Carolina
    Nbs flywheel bolt on left. Obs bolt on right
