Results 1 to 10 of 59
Thread: Hulknasty's 95 5.3/60e swap
    Apr 2014
    Ep381 was for the L31 truck engine. It was designed to run at 58-62psi. It has enough fuel to support 400hp but above that it can't supply fuel fast enough. As I recall it is rated at 180 liters.
    Sep 2014
    Quote Originally Posted by Skylark View Post
    exactly^ no plans to go crazy with power on this truck so the ep381 should work fine
    Sep 2014
    Is this what I need to make my engines steam vent functional with my 95 k1500 radiator??
    Nov 2013
    Fort Hood, TX (for now)
    I was looking at that option ^ or something similar for my steam line. As opposed to drilling and tapping my water pump or stat housing. By the way, running a/c really isn't difficult at all, especially if you get the bracket kit from lextech. I bought it and it looks good and fits perfect, totally worth it, can't wait to be blowing ice cold air this summer!!
    Sep 2014
    yeah..im just skipping it for now. its never worked so dont think id really miss it honestly. on a side note I just noticed that my radiator has an extra port thats plugged off. Wonder if I can just run my steam line to that instead
    Sep 2011
    Quote Originally Posted by Hulknasty View Post
    is the port on the radiator cap side near the top? I used that port on a swap on my 94 model 2 wheel drive truck for the steam line and have had no issues
    Apr 2014
    Quote Originally Posted by Blasphemy View Post
    His is a 95. Lextech's kit is for the 96-00 with the vortec engine.
    Sep 2014
    Got the engine/trans and transfer case dropped in last weekend. Wiring harness came today and I have most of It hooked up now. Im running the stock 1995 241 transfer case. Does anyone know the best way to hook up the vss on this to the ls wiring? Do I just need to splice the old plug onto the new harness?
    Sep 2014
