					I am almost done with a 5.3/t56/14bolt swap into my 95 ecsb. 95 is still TBI so your fuel system operates at about 10-12 PSI IIRC. So you will need a stock vortec 96-98 fuel pump because the ls engines need 58 PSI. It is AcDelco Ep-381. Or you could go for something like a walbro 255 if you plan on more power in the future. Here is a link to my build thread, I haven't gotten around to starting one here yet. I also stopped posting as much in it. I can try to answer whatever questions I can, but remember I did a t56 and was 5 speed to begin with so I can't help with that.
 http://www.gmfullsize.com/forum/showthread.php?t=259002
- You may not post replies
- You may not edit your posts
