sick build richard
sick build richard
97 xcab c1500 lm7 5.3 swap 343RWHP 329RWTQ 13.40 @ 101.97 2.03 60ft. MODS: Longtubes, 3200 stall, TR220 112lsa, .030 799 heads, NNBS intake, PTM 92mm TB. 4" PVC "hot" air intake 3" single exhaust w/cutout 3.42:1 gears, 29" tall tires. Dyno tuned by flaco
Awesome build! Also those are some good looking cars as well.
Trey
nitrousexpress.com
facebook page
youtube channel
join newsletter
Pm, Call (888)463-2781, or email Trey@nitrousexpress.com for Tech or sales
MADE Proudly IN THE USA
subbed.!!!!
Got a few updates for you guys. motor is in!
Had to track down an unlocked PCM in a crate full of "tuner locked" PCM's. took me about 4 tries, I brought it home and bench flashed it using the PSI harness hooked up to my car lmao
Took me a few tries to sit it down because the Motor mount on the passenger side was too stiff.
NNBS intake and TB/42lbs injectors mocked up on the intake. I'll need spacers for the rail mounting holes unfortunately but no issues for me.
used this little bad boy on the stock fuel pump assembly, hand me down from my trans am and should fuel it well enough for a 100 shot
Got 20 foot of rubber 300PSI -6 line, hose ends, and O ring to AN adapters for the fuel pump assembly. I used straights here and 90's up by the firewall for the corvette fuel filter
Still need to push the fittings themselves further into the hose but the picture gets the point across lol
Ordered a true trac locker and 4.10 gears, picking up the caltracs tomorrow as well.
Shortly after that, Me and a buddy are going to see if these TSP 1-7/8 Fbody headers will fit the truck, if not, then I have a set of schoenfelds new in box. I would rather have the advantage of the 1-7/8 though. especially with nitrous.
