Page 6 of 6 FirstFirst ... 4 5 6
Results 51 to 59 of 59
Thread: My 1999 OBS C1500 LQ9 6.0 LS Swap
  1. #51
    Apr 2011
    Quote Originally Posted by Chevydillan View Post
    ^^^ I bet the 60 would be just fine in that situation but a trans go HD-2, sun shell and 5 pinion planetary would for sure do it. Oh and of course a good cooler.
    cool! what is a trans-go hd2 and what sun shell do i use, one from a 4l65e or?
  2. #52
    Jan 2014
    Las Cruces NM
    Look up beast sun shell on eBay and the trans go is a shift
    Kit.
    97 RCSB . 2WD . 5.3 . 4l60E . E-FANS . PNP 706s . TSP 228R . 3600 STALL . HD2 . VETTE SERVO . 3.73s . 2" DROP
    TURBO IN THE WORKS
  3. #53
    Apr 2011
    Kit.
    I saw that beast sunshell. Will that sunshell change anything or is it just a strong version of the stock sunshell? I dont wanna change the way the trans acts or anything, just make it a little tougher and i was told the stock sunshell is weak..what about this one
    http://www.ebay.com/itm/Sonnax-SMART...29ef0b&vxp=mtr
    Its supposed to be tougher than the beast AND addresses the planetary problem also..
  4. #54
    Jan 2014
    Las Cruces NM
    That looks good and sonnax is quality stuff. The hard parts don't change anything but strength.
    You should probably start a new thread so we don't jack this one any longer and you may get more/better responses.
    TURBO IN THE WORKS
  5. #55
    Quote Originally Posted by ChevyMan90 View Post
    I do plan on putting A/C back in the truck. I will have to buy a bracket to mount the compressor. The wiring harness I am using has an A/C signal wire that I will have to use in order for it to all work. Here is a picture of how the headers fit. I'll have to get another for the oil pan.
    That looks like plenty of room... I plan on body dropping my truck after I finish another car I'm working on and long tubes that stay above the front frame rails are hard to find.
  6. #56
    Well the wiring is finally cleaned up and loomed. I think it came out pretty good. The only gauge not working is my fuel gauge. I did a bunch of searching and repinned the LS PCM with the 2 necessary wires from the factory black box computer and it still isn't working. I had adjustments made in the tune and still have had no luck. If any of you have any tips for me let me know! Just wanted to share a few engine bay pics. Still have a few little things here and there I want to fix up but its 99% done. It sure is fun!
    1999 Chevrolet C1500 2WD
    LQ9 6.0 . PRC LS6 Heads . TR 227/239 Cam . TBSS Intake . LT Headers . 3.73 . TruTrac . E-Fans . Built 4L60E . PI 4000 Stall
  7. #57
    May 2007
    Oak Forest, Illinois
    There are no tips for the fuel gauge. It has to be corrected in the calibration.
    Jeff
  8. #58
    Dec 2012
    Pasadena, Tx
    You should get a NNBS intake
  9. #59
    This is a NNBS intake. Thats why I modified the fuel rail crossover.
    The NNBS and the TBSS intakes are the same thing.
