Not sure about the 4L80E, but when I put a newer 4L60E (cable actuated)into my OBS, I had to modify the original linkage bracket mounted on the shift shaft of the transmission to get the column shifter to work properly. If the 80E is cable actuated, you may have to go this route as well.
