Results 1 to 10 of 15
Thread: LQ4 cam upgrades with 243 heads in Tahoe?
    Pittsburgh, PA
    i wouldnt use the LS6 cam for that build and how is a tahoe 6700lbs being 2wd?
    i would look for a cam around 212 around 580 lift with a 114...this would give you a good bit of torque and dynamic compression would be pretty decent aiding in cylinder fill so torque would be up and be done around 5500
    2014 Xsport- 3.5 Eco boost
    412 Motorsports
    Quote Originally Posted by George C View Post
    Now I see how you get over 6000 posts! You read them fast! I said it was a 4WD, but a 2 door.
    But good advice all. I was hoping that if any cam was a good replacement, it might be a common one that people would replace for "more" cam so I might be a good used one.
    Pittsburgh, PA
    Quote Originally Posted by Goldhawg View Post
    6000 post isnt much especially since i been around for almost 7 yrs
    still curious how your 6700lbs
    412 Motorsports
    I was wrong, remember it was over 6k; GWVR is 6100lbs.
    Pittsburgh, PA
    is that what you read off the door tag?
    412 Motorsports
    Jan 2014
    Las Cruces NM
    I believe GVWR is the maximum weight the truck can safely cary. People, fuel, luggage and crap in the back. Not the actual weight of the truck.
    Pittsburgh, PA
    Quote Originally Posted by Chevydillan View Post
    correct. its typically 1000lbs more then actual
    412 Motorsports
    Arizona/Utah
    212/218 is an extremely common used cam. Probably very close to as common to the LS6 in other applications.
