Page 2 of 2 FirstFirst 1 2
Results 11 to 19 of 19
Thread: Need some turbo insight...apologize up front for any redundant questions
  1. #11
    Oct 2005
    Quote Originally Posted by George C View Post
    i ran a T56 5.3 setup, ran well but FYI the manual route is going to be a rough and expensive path.....it may seem cheap at the moment but sure isnt
    also have to look at what you want from truck in long term as for power. a 70mm may be fine today but how will it be tomorrow when your bored?
    I have had the 5.3/T56 combo in the truck for about 5 years...so that money is already spent. LOL It was pricey, but I still like the manual. Plan was always to add turbo later, but had kids, bought a farm, you know, became an adult, so am just now getting back to working on the truck.
    thanks for the help
    '92 Fullsize, swb rc
    5.3L/T56 conversion, comp XR275 HR cam .566/.568 lift 222/224 duration 112 lsa, crane dual springs, trick flow push rods, K&N Filter, Nelson Performance tune, Keisler shifter relocation kit, Boyd Coddington Smoothie II 18x8 235/55 up front, 18x10 295/45 out back, 2/4 drop, eaton lsd w/4.56 gears
  2. #12
    Oct 2005
    Thanks. This helps a lot. I like the looks of what you have, and the only thing wrong with your hot side plumbing is that it isn't on my truck. haha.
    thanks again
  3. #13
    Pittsburgh, PA
    stock trans wont hold big power, stock hydraulics wont hold aftermarket clutches, twin disk clutches arent cheap...i spent more on the manual boosted setup then i could ever imagine
    i sold my old kit to a member on here
    2014 Xsport- 3.5 Eco boost
    412 Motorsports
  4. #14
    Jan 2014
    Might as well say $1 per horse for a clutch.. and that's playing on the cheap side... not to mention builting the trans its self
  5. #15
    Oct 2005
    I gotcha, I was thinking differently on the initial post.
    thanks
  6. #16
    Pittsburgh, PA
    Between clutches, trans and trans parts, cross member, pedals, hydraulics, slaves and etc I have around 12,000 wrapped up
    When I finally seen my firewall torn between the master cylinder and wiring harness hole is when I called it quits
  7. #17
    Oct 2005
    Lordy...That is a lot of money at my house. I can understand going a different direction.
  8. #18
    Pittsburgh, PA
    Quote Originally Posted by LOWnEASY View Post
    also remember clutches are rated for cars, when using them in a truck allow yourself alot of room for the weight. If you find a 1000 rated clutch id say your fine till about 700...thats one of the clutches that i used....Spec twin disk rated for 1000...died when i went over 800
    412 Motorsports
  9. #19
    Oct 2005
    That is generally what I have had in mind. this set up won't get beat up constantly...only occasional abuse.
    Driveline isn't stock, but isn't built for 1000hp either
    Thanks again for the help
