Page 3 of 8 FirstFirst 1 2 3 4 5 ... LastLast
Results 21 to 30 of 73
Thread: Conversion Progress Report
  1. #21
    Aug 2011
    Ellsworth Air Force Base, SD
    I must have looked at this website a 100 times and don't know how I missed that, thanks for the link, sincerely.
    1994 Chevy C1500 RCSB 05' DBW 5.3 Conversion Complete
    My build
    Coming soon ....... Full Repaint, 214/220 Cam, Yukon Posi with 3.73's, remove body lift
  2. #22
    Jan 2014
    No problem. I missed twice lol.
    I'm still not getting what you mean by the 94 ish connector. Is it a stock connector on the truck?
  3. #23
    Aug 2011
    It's the C100 that goes thru the drivers side firewall. Yes it's the stock connector.
    My build
  4. #24
    Jan 2014
    Try this. Its mid way/tword the bottom of this page
    http://www.truckforum.org/forums/che...vy-only-3.html
  5. #25
    Aug 2011
    Alright, the front portions of the fuel supply line done. I took the supply fitting from the old TBI and reamed it to .372 which is OD of the fuel rail where the push lock fitting would have gone.
    I then pressed fitted the old TBI fitting on the back of the rail and TIG welded it in place, then painted it.
    Here it is installed back on the truck with the old factory line attached back to it.
    I think I might be able to reuse the push lock that came off the rail to make my supply and return the same length to the vette filter. Being as it was cut and it's just a thin plastic tube with braiding round it, not sure how a would do getting clamped back into it.
    My build
  6. #26
    Jan 2014
    Las Cruces NM
    Sub'd for some great work
  7. #27
    Mar 2013
    Long Beach California
    why not just use the earl connectors for an line and be done with it vs trying to rig the old lines? an lines are damn near leak proof. plus they just look awesome with braided stainless. lol
    CALI LEGAL ENGINE SWAP!
  8. #28
    Sep 2012
    Quakertown, Pa.
    Looking good. I guess you're glad to be back on track after the yearlong hiatus.
    John
  9. #29
    Aug 2011
    Quote Originally Posted by kewljay223 View Post
    Agree, but I already have a easily adaptable fuel line that ended up costing me nothing. The braided lines do look great, but they are expensive and when the hood is open you can only see a few inches that line. Maybe my next swap will have it.
    My build
  10. #30
    Aug 2011
    Quote Originally Posted by Mickeymotormount View Post
    Thanks, I am glad to be back on track. The year did give me time to think about all the things that need to be done vs what I want done. Got to machine a bunch of little parts and fittings that probably saved me $150 or so.
    My build
