96-98 pump will work. since the tanks are the same as the 91 it should be a fairly easy swap. or go to a pull a part & grab a whole tank & everything from a 96-98.
you going to have to make or have some lines made. i had to make 2 short lines to go from my factory truck lines to the vette filter, then a new line from the filter to the rail.
