Remember howards will custom grind any cam you want for 40$ over their normal pricing, unlike most cam suppliers that charge outrageous prices for. Custom cams with a decent lift.
What frame did you use/wire harness? Did you retain stock gauges or go aftermarket?
It has the stock 41 frame under it with the front cut off and the 79 tran am front clip welded in it overlaps about two foot which makes a very stiff frame. It has the trans am 403 tranny and rearend as well. The steering column and harness is out of the car but now I am grafting the 5.3 harness into the ignition so the only wires left from the car are in the column and the gauge lights. I am running an aluminum gauge cluster with dolphin gauges
