Results 1 to 10 of 26
Thread: * * * 5.3 swap with 4L60e and other questions ... * * *
    Mar 2013
    Long Beach California
    what vac lines are you reffering to? afaik, there is just the one on the back for the brakes.... which im pretty sure is blocked off due to the hydroboost... but if your running vac for brakes, then all you need is the nipple to replace the plug and run your stock hose from booster to the back...
    CALI LEGAL ENGINE SWAP!
    That is what I am referring to. Where can I find that adapter or nipple (LOL) ??
    Oct 2010
    Southern California
    You can't use your 94 4l60e trans. It needs to be 95 and newer, because the 94 doesn't have enough pins in the trans. socket connector. Got to be 95 and newer.
    I ready resolved that prob. Internal harness upgraded to '95 & up one with the extra pin.
    Quote Originally Posted by kewljay223 View Post
    I just took care of that issue this morning. Going to double check my grounds today and cross my fingers
    hey guys. I finally got her up and running. I am down now to the transmission. I need to look up the TCC switch from the LS PCM on to the OBS. How would I accomplish that? I have set the ls harness as stand alone. I have a purple wire that is suppose to go to the tcc switch. Is there a wire in the engine bay from the obs that I can simply tap into? Or run inside the cab and connect it to the brake switch?
    Mar 2013
    driver side upper connector. test to make sure by having someone hit the brakes while your out there with a meter.
    Got it thx !! She goes forward and reverse now !! Lol. Trying to finish the e fans tonight, add coolant and its ready to smoke the tires !!
    I had the truck running and looking for leaks and I saw the brake booster hose. It collapsed (see pic). I have this connected to the rear of the intake manifold. I did use a regular fuel injection house laying around. Should I use a plastic one instead? Or did I hooked it up wrong?
    Mar 2013
    LOL!!! thats hilarious. i must say ive never seen that before! OBVIOUSLY you need something stronger. just use some kind of hose that has the "threading" in between the inner and outer layers..... i.e. heater/coolant,oil,fuel etc... That is a VACCUME hose so it needs to be strong enough to resist the suction.
