Your truck isn't that different from my '93 1500 4X4. Let me see if I can answer some questions:
Fuel pump:I believe you will need to have a '96 or later fuel pump for the Vortec injected engines. These pumps create higher fuel system pressures needed for the LS engine to run.
You can use the original fuel pump relay. The only wire that needs to be undone from the relay is the dark green/white wire in position D of the relay plug. This is the relay actuating wire from the old PCM. You will now need to run the same dark green/white wire from the new PCM, position #9, connector C-2(red or green, depending on year of engine being swapped) to the position D of the fuel pump relay. Basically, you're swapping out the old PCM relay control wire for new PCM relay control wire. It just so happens that they are the same color.
As for the power distribution block, I left all my wires attached since they power certain interior functions which have nothing to do with the engine swap. You can pull 12V from that block and fuse it for a constant 12V source for the PCM. You will also need a switched source of 12V for the PCM.
