i did this swap, followed this tut. everything works, tranny shifts fine, speedo works no issues. however, tow haul isn't working. i'm using a t42 tcm out of a 08 van with the 80e... anyon else have this issue? btw this is an a 08 rcsb sierra
glad it's helping others.
i really need to update this thread, things have changed so much.
Nelson Performance
FastestTruckList.com
NP on Facebook
Youtube Channel
Know this is a old thread but wanting to do the 4l80 swap on my 2011 GMC Sierra that has the 6l80 and autotrac transfer case. What all is needed to buy for this? Did you guys fig out the 4x4 issues? Im pretty sure i won't have any issues fitting my transfer case to the 4l80 as its the same input and bolt pattern as an Atlas transfer case from what I'm told and trans adapters has the right adapter for it already. Will it still work and function correctly tho? Also I wouldn't mind dropping the truck off at Nelson if he can do the whole swap for me as long as everything still works 100%.
2011 GMC Sierra 4x4 427 LSX 6-Speed
