					worked on it today.  but was only able to work on the fuel tank.  ran into a few issues.  only one major one tho and that almost made me flip....  i thought i was gonna have to buy another fuel tank!!!
 here it is about ready to put in the newer style assembly from 96-98 trucks.
 EEEEEEEVVVVVVIIIIIDEEEENTTTTLLLLYYYYYYY.......... GM thought it was a good idea to change the size of the opening on top of the tank rather than just keep it the same for the next 3 years untill they changed body styles.....  the new assembly will not fit!!!!  not even close.  luckily nobody was around at the time i tried to install it.  there might have been some injuries.
 so after a little rant, i sat down and studied both assemblies to see if i could come up with anything.  and i think i did.  my dilema was that i needed a higher pressure pump AND a pressure sensor which the old unit doesnt have.  but i had luckily already bought the 381 pump that i thought i was gonna need before i realized i could just use the pump from the newer assembly which i asked about a few pages back.  so i knew i could install that.  problem 1 solved.  now on to the pressure sensor.  the old unit uses a vent hose that goes to the gas cap to relieve fuel pressure when the tank heats up on OBD1 vehicles.  OBD2 has a pressurized tank which eliminates that hose and now has a pressure sensor.  BAM!!!  thats when it hit me.  use the vent hose to supply the pressure sensor.  so i removed the sensor from the new unit, got some arb fittings to adapt it from 5/8 to 1/4" and some fuel hose and put the sensor on the end.  i will have to mount the sensor in the framerail somewhere.   but as long as there are no leaks, this should now make the tank pressurized and i dont see how the referee could care thats its not mounted on the unit itself.  it should still read the pressure just fine.  heres the new rig... looks kinda ghetto but i think it should work.  Please tell me if im not seeing something
 i know this doesnt apply to most of you but since there is VERY LITTLE info on CARB legal swap "how to's"  im trying to keep my thread as detailed as possible on how to hook up all the nessesary smog equipment for anyone else trying to do this kinda swap since im going through hell and back to figure it out on my own.
 ill be working more on the tomorrow.  hope to get the vapor canister, vent solenoid and wiring all mounted and hooked up so that the tank portion is finished.  i hate trying to crawl under this damn truck!!
- You may not post replies
- You may not edit your posts
