Page 4 of 19 FirstFirst ... 2 3 4 5 6 14 ... LastLast
Results 31 to 40 of 183
Thread: 6.0 into 98 OBS
  1. #31
    Mar 2013
    Lookin good, what you use for a degreaser?
  2. #32
    Sep 2009
    NE Ohio
    Quote Originally Posted by smkur50 View Post
    Thanx. I just used that Gunk brand in a can. Did it twice.
    Been lurking since 09 and I finally have my kickass 6.0 LQ4
    LQ4 LQ9 6.0L Engine Service Manual Save to your computer in case it disappears
  3. #33
    Sep 2009
    NE Ohio
    Took the heads off and cleaned some more.
    And my pile of stuff in a corner of my work bay.
    Still deciding on if I want to do a cam as I am already this far and now would be the perfect time to do it. Next I need to order all the gaskets to put this back together.
    This all began when I pulled the intake to start the wiring and hide it under the intake and make it a nice neat & clean install. I am REALLY glad I pulled it. I never would have seen all that needed attention. The intake gaskets were dry rotted and cracked to hell causing water to leak in from when I hosed it down. Aside form the fuel pressure regulator dumping fuel up the vacuum line and straight into the intake, and filling the oil pan with gas, making it run rough and eventually not start I can only imagine that the cracked gaskets werent helping.
  4. #34
    Sep 2009
    NE Ohio
    Will my 98 trans, 2WD 60E, mount up to this AWD 6.0? I have been thinking about that. I have read so many swaps and there A LOT of mixed answers. I have heard you just swap over the 98 flex plate to the LS. My LS has the extended crank.
    If I can use it then I will wait till I break it to swap over the 65E.
    Anyone need and AWD transfer case? I have one for sale.
  5. #35
    Sep 2012
    Quakertown, Pa.
    Check out this link. It may answer some of your trannie questions.
    http://www.hotrodlane.cc/PDFFILES/Lisa%20Tahoe.pdf
    John
  6. #36
    Sep 2009
    NE Ohio
    Well I cleaned up some aluminum parts in the parts cleaner tank today and painted the valve covers. No pics though. I forgot all about taking some. I will get some and post em up tomorrow.
    I still need to paint the timing cover a start ordering some parts such as a complete gasket kit, timing set, front and rear seals, and a cam.
    What cam do ya'll recommend?
    I am looking at the TTR-220 or a Comp Cam XFI Xtreme Truck.
    I want this thing to be streetable as it is my DD and I want to be able to take it to the track and play every once in awhile.
  7. #37
    Sep 2009
    NE Ohio
  8. #38
    What color is that? Looks real nice.
  9. #39
    Sep 2009
    NE Ohio
    Its actually a Subaru exterior color.
    Quartz Silver Paint Code A7K
  10. #40
    Sep 2009
    NE Ohio
    Primed and painted the block.
    Even though it wont be seen, I am gonna highlight the 6.0L on the front of the block.
