Page 2 of 2 FirstFirst 1 2
Results 11 to 17 of 17
Thread: wheel speed sensor and brake booster delete
  1. #11
    Pittsburgh, PA
    my truck has no auto wiring in it anymore...need a few wires from harness and your good least in my case...a th400 you could techincally ditch it all then.....you can also get a hot rod harness
    2014 Xsport- 3.5 Eco boost
    412 Motorsports
  2. #12
    Sep 2011
    I should have unplugged the prndl switch and tried to start it before I removed half my engine from the truck. I'm just trying to make sure that if I delete all tranny wiring that my truck won't think its in gear and not spin over. I would like to just modify my harness since i already have it. Probably gonna ditch the 400 and put a glide in it. Can someone look at pin # 33 on this link and please elaborate. http://www.lt1swap.com/99-02_vortec_pcm.htm
    99 rcsb silverado...... boosted.
  3. #13
    Pittsburgh, PA
    i posted on PT.net back in 07 about what wires needed to do what.. look for name quik in the T56 thread
    Quote Originally Posted by jansen View Post
    412 Motorsports
  4. #14
    Sep 2011
    Thanks George! I'll do that!
  5. #15
    i know edgar aka roadkill from the valley is deleting his brake booster now and not going hydroboost ( could be wrong but doubt it ) he bought the parks from burkhart performance if not mistaken .. he also deleted ABS and the BS that comes with it
    Simple: 408 on steroids!
    single digits coming soon!
  6. #16
    Sep 2011
    After reading this post last night I did a little research and found the burkhart kit for the f bodies. With a little further research I found that the f body guys are also using a manual brake cylinder from a 89 dodge caravan. Gonna swing by the parts house this week and check one out . thanks for the tip skeet!
  7. #17
    Mar 2011
    Gibbstown, NJ
    o2camaross currently has a th400 in his truck now. PM him and ask him what he did to his truck to get it all straightened out.
    2001 ECSB Z-71: 7.0L LS7, Kook's LT's, True Duals, RPM Tune, F.A.S.T. Intake/TB, YANK TT3000, 4:10's, G80, AWD Swap, 160-Stat.....
    Slowest in South Jersey ..........SOLD :-(
    2012 GMC Sierra Z71 CC: 6 Speed, 3:73's, G80, Back up DD...........SOLD
    2000 RCSB Shitbox.......370LSx/Built 60e/4.56's,EATON Posi, CAI,3" SLP Exhaust, DD.......Build Thread http://www.ls1truck.com/forums/my-ga...ker-punch.html
