Results 1 to 10 of 11
Thread: When to Upgrade the Stock Transmission?
    Mar 2013
    Sounds good!! Thanks to all. I'll keep it until the clutches give out, then put a good kit in there with a good stall.
    Arizona/Utah
    Quote Originally Posted by griff364 View Post
    A good stall would be an excellent mod right now. You can drop your 60' a lot swapping to a higher stall and thus dropping yoUr 1/4 times. I wouldn't worry about the trans itself takes a ton of abuse.
