Results 1 to 10 of 11
Thread: Need help guys...
    How much of a budget you got? Rancho RS9000s are great unless you want to step to like a QA1 or something along those lines.
    how low is the drop, what drop and what shocks are currently on the truck?
    Feb 2013
    San antonio,tx
    The drop is a 4/6 flipkit on back n i currently have the stock shocks..
    4.8 FBO-PULLEY 228/228 CAM 4.10 GEARS TUNED BY NELSON...JUST CRUSUIN SAN ANTONIO!
    4/6 without a notch?! I'm on a 2/4 and bang the frame constantly. You sir need a notch first. And consider some shock extenders, or even completely remounting the shocks so they're vertical.
    Unless you have a 07+ I don't think they need a notch for a 6" drop
    Feb 2013
    San antonio,tx
    True my diff. Is sitting with the frame lol but thing is i don't know anybody locally that can do a c-notch thats why i wanted to put air shocks or some other types of shocks to prevent it from hitting...
    Oct 2011
    San Antonio TX
    Shocks wont stop it from hitting. U need a notch first. Theres got to be a write up on how to install them floating around here. I have a nnbs on 7" rear drop and its rare if it hits.
    Best ET 11.54@114 w 1.52 60ft
    Raceweight 4905 lbs.
    Feb 2013
    San antonio,tx
    Quote Originally Posted by RS/SS 4.8 View Post
    Yiu don't know of a shop here in sa that can do a notch?
    Jan 2012
    DFW, TEXAS
    i have a classic nbs, with monomax shocks all around, and it would on hit if i had 200+lbs or hit a dip. but invest in a notch. check every truck forum you can someones got one cheap
    Feb 2013
    San antonio,tx
    Anywhere from 100-150 should be fine as long as its gnna help me out
