Results 1 to 10 of 35
Thread: 243 LS heads - fully assembled
    Jan 2012
    Anacoco, La
    Quote Originally Posted by MrHorsepowerLSx View Post
    Larger combustion chambers will lower compression if the heads they are replacing had smaller chambers, example an 06 lq9 and an 06 ls2 use the same pistons, the lq9 uses a 71cc chamber and the ls2 uses a 64.5cc ( even tho GM displays it at 64cc ) the lq9 registers a Compression Ratio of 10.1:1, the ls2 with its smaller combustion chamber with the SAME piston it will yield an 11:1 compression ratio. This example was given based off of identical bore x stroke combos based off of a 4" inch bore using identical pistons..... Hope this helps bump
    Thanks!!!! Least somebody knows wats going on
    Arizona/Utah
    Quote Originally Posted by bootlife View Post
    I think you are trying to argue something completely different. All stock 243s are the same no matter what motor they come from minus the valve thing. Different motors will net different cr according to a lot of factors that have little to do with the heads and everything to do with pistons, stroke, etc. Not all 5.3s are created equally, but all 243s basically are.
    Let me go ahead and reiterate something I've said about you multiple times... you're literally the dumbest guy on this forum at this point. Please, do us all a favor and don't speak.
