How strong is that kp 4 link? Can they handle a good amount of power? And are they good for drag racing?
called kp n they sell the weld on for 960 n bolt on for 1300 with coil over n everything u need. kp tech guy said bolt on is rated to 500 hp n weld on is 500 hp+
Hmm, I'll just prolly build my own when the time comes. It just doesnt seem to be really drag friendly. Doesnt look very adjustable. But, If you are staying N/A, it should work for you just fine
Applied racing sells Weldon kits very good quality for a good price. About a grand for a really good kit
Here's is one kit from applied racing we did on my brothers truck.
The Kp components really are not that good for drag racing because the bar's are not adjustable you can only lengthen or shorten the bars. I have there 6 link setup on my truck and it hooks amazing but with bags it has much better weight transfer with the cantilever setup.
Qa1 coilovers don't remember the exact price on the coilovers but the whole 4 link kit was right at a grand for everything. As far a bolt in I would not use those but to each his own. These kits are fairly easy to install if u can weld and have a few tools in your shop. Totally worth it in the end!
