Results 1 to 10 of 11
Thread: shift kit and stall
    Mar 2006
    I had a 2600 yank stall put in and also went with the transgo shift kit. On a wot run when the
    Jan 2005
    Conway, AR
    huh?
    Mar 2006
    well that didn't work well , anyway when the truck shifts from 1 to 2 gear it makes a loud squeaking noise as it shift is this normal ?
    Jan 2005
    Conway, AR
    are you sure its not just the tires barking? If not, it could be the suspension creaking.
    A lot of people complain about that. Some think it's the fan belt slipping. Others claim replacing their stock 1-2 and 3-4 servos fixed the problems. Personally, I've never experienced it through 5 transmissions.
    If you're running a synthetic transmission fluid, replace it with conventional transmission fluid. The clutches in a 60E can't handle full synthetics in a performance application, it's too slippery and the clutches will not hold.
    Mar 2006
    I also replaced the 1-2 servo. I am running stock trans fluild and its not the tires i hear that also but this is another noise. I have heard some trans. do this after a shift kit and some don't. I guess it is ok it shift hard and quick. I guess it could be a fan belt?
    Mar 2006
    Dawson Springs KY
    <div class='quotetop'>QUOTE(acman &#064; Apr 21 2006, 07&#58;23 AM) [snapback]50651[/snapback]</div>
    I would say that very possible. Your pulling the engines rpm down a lot quicker that you were before.
    2011 Silverado LT 5.3 bone stock (for now)
    (gone but not forgotten)02 Avalanche Z-71 Vortech supercharged 3.12 pulley 10psi, SMC meth injection, 33 12.50-17 procomp AT, 17x9 procomp wheels, AVIC-N2 NAV, 4.56 gears, Detroit TrueTrac, 2500 stall converter, transgo HD2 shift kit, Vette servos, 80mm BBK throttle body, Edelbrock shortie headers Cold Fusion wet shot (60hp), and too many more mods to list. 8.86/18th 472rwhp/499rwtq
    Nov 2005
    San Jose CA.
    Mine does the same thing, I was thinking it was the bands? Hard to isolate the sound when you&#39;re throttled wide open&#33;
    626/762 2005 SIERRA 11.34@119.81
    My other ride is a '91 Electraglide custom.
    Sep 2004
    Breaux Bridge, LA
    i&#39;m pretty sure it&#39;s the serpintene (sp?). that&#39;s what it sounds like. pretty much normal
    11' Sierra 6.2 NHT
    14.46@91 Stock
    89' Mustang LSX
    10.35@130 pump gas LQ4
    Knothead Racing
