Results 1 to 10 of 17
Thread: need some oem specs....454
    Jun 2011
    Clarksville, TN
    Holy crap that CR is sooooo low. Kind of begs for boost.
    Yep, its def getting a blower....I googled it but kept getting same info....all 70s models....but this is a gen v and I wanted to know what was different on it vs the older ones
    Arizona/Utah
    Quote Originally Posted by demonheavymetal View Post
    http://www.performancetrucks.net/for...-507406/page2/
    Blower for that motor on the cheap.
    Jan 2007
    Stafford, VA
    I'd venture to assume this is a truck block which has a larger deck height (10.4" vs 9.8" I think?? Been trying to look it up online, but Internet is slow at work, lol!) This makes a difference in the intake and headers you are looking to purchase. The intake has to be wider than the passanger block intake would be (or you have to use spacers). The headers will sit higher as well, so need to be a bit longer for body fitment. Luckily both options are easy to come by, it's just you have to plan for them. All internals and bolt patterns are the same. You'll also need to consider this for the front mounting brackets for anything mounting off the heads (alternator comes to mind) as it's a little different. Just thought I'd mention.
    - Paul J.
    2006 Silverado LT3 L33 Z71 - Mods: K&N Air Filter; Taylor Wires
    2008 Azera Limited - Mods: (Yah, wife's car ... not happening)
    (SOLD) 1994 Camaro Z28 - Mods: (Too many to mention)
    (SOLD) 2004 Suburban 5.3L Z71 - Mods: Flex-a-Lite 292 Monster Fan
    (SOLD) 2000 Silverado 5.3L Z71 - Mods: (NTIKO)
    (SOLD) 1991 Suburban 350 2WD - Mods: (NTIKO)
    Quote Originally Posted by Paulster2 View Post
    The intakes are interchangeable without spacers.
    Round Rock, Texas
    Mill/deck to bring compression up, work the heads, good exhaust, good ignition system, then add boost if you're not happy with the results naturally aspirated. And make sure its carbureted.
