Quote Originally Posted by darnie1987 View Post
ya i clamped the front side of the springs. and you think i need to have it lowered? the rpm ... its shifting around 6200
I would be shifting higher then that, 6.4k and also raise your rev limiter high enough that you do not hit it. Your springs good enough to not float at that RPM?
Your recovery should be higher then that with that stall speed. Looks like your hitting limiter to me or it would be higher then that, 4.5K is what I would expect to see.
