Results 1 to 10 of 20
Thread: Truck Side wiring
    Jan 2012
    Petal, Ms.
    For the tach on a 92 silverado I connected to the white wire that was on the coil, using the red wire that was on the coil for ignition switched power. But even using the white tach wire that was on the coil you need a 680 ohm resistor. It will read only half rpms that you are running, I don't know how to get that straight but its better than nothing. you are right also with the existing fuel pump relay tie into the green/wht wire. Hope this helps.
    Dec 2010
    Quote Originally Posted by Dustytrix View Post
    Appreciate the input.
    Jan 2012
    Petal, Ms.
    For the speedometer I ended up splicing the vss wires from 04 computer into the vss wires on the transmission this makes a 3 wire splice for both colors (6 wires total) that made my speedo start working
    Dec 2010
    This is lacking a lot of info.... details?
    Jan 2012
    Petal, Ms.
    Take the vss wires from donor harness and just splice them into your existing vss wires. Your existing wires will stay hooked up as original.
    Mar 2012
    x2 on that!! I did the exact thing as this and it works just like it was factory. I also used the white wire on the coil for tach signal and the red for switched power to my coil packs and injectors. but i didnt have to use a resistoron my tach and mine registers right so...
    Dec 2010
    Quote Originally Posted by Clayman View Post
    Thanks much!
    I started tearing through my harness today, and it appears my IAT plug was cut off. Didn't make me happy to discover that, but IAT harnesses are easy to come by so I suppose it could be much worse.
    Jan 2012
    warwick ny
    http://www.ls1truck.com/forums/lsx-t...eedometer.html Also do a search in this forum "speedometer" and you will find a lot of info and pictures.
