This has a bunch of crap that goes inside that you dont need.
another one
You can find the connector in AllData and start going through what each one is for. On most of mine I started back at the connector that I knew I wasnt using and came towards the pcm or fuse block with the wire until I got to where I needed to just depin it.
i'm guessing these are all the pink power wires i need to deal with but i'm not really sure where to look for it in all data.
Right is MAF and left is coolant level I believe
Those are A/C
O2 sensor
