Results 1 to 10 of 19
Thread: Viper Alarm Install - Need some pointers
    wichita falls, tx
    What year is you truck?
    The one main thing that I will say is use a tach signal don't rely on there voltage sensing setting even though viper is the best one using that technology, I sill would rather have a tach signal to tell it to turn the starter off rather than relying on voltage.
    And soldier all of your connections, no t-taps scotch locks or butt connectors because all of those can make for unreliable performance. Also I would use scotch super 33 tape to cover all of my connections.
    Mar 2011
    Amarillo TX
    Quote Originally Posted by dropem View Post
    It's a 2000 ECSB. As far as the connections go, I had planned on using t-taps for all the small gauge wires, and then soldering the larger ignition wires for the remote start. Enough people have told to solder everything that I may have to do it that way. I don't want to be chasing wiring problems a year from now, that's for sure. I'm under the impression that a lot of wires on those harnesses you just tap into with the viper harness, leaving the original connections intact. What is the best way to tap into these wires and still use solder to do it? I wanted to use the t-taps to avoid cutting the factory wires as much as possible.
    Thanks for the help.
    2000 ECSB 5.3L with K&N CAI, true duals with flowmaster 40s, and 200k miles!
    wichita falls, tx
    I wouldn't cut the wire i would just strip the shielding off of about a 1 inch section and wrap the viper wires around the factory wire and then solider them on that way covered with tape.
    Mar 2011
    Amarillo TX
    Along the same lines I was thinking just now.
    I'm gonna be making sure to read through the manuals really well over the weekend, assuming ups drops it off on time, and will probably have more questions then too.
    Feb 2012
    Mcalester ok
    Totally agree with this butt remember the physical connection is better than solder. What I mean is make sure the wire is wrapped up good before soldering
    Long story short I had a Viper alarm "professionally" installed about 10 years ago, It worked for about a month and then all kinds of stuff started happening with it. We ended up just unhooking it, because I kept having a dead battery. When I took it all apart I found out they used all wire taps on it, there were dozens of wires done like this and boy did it make me mad!!!
    Me personally I wouldn't use wire taps on a go kart...Solder solder solder
    Mar 2011
    Amarillo TX
    Quote Originally Posted by Slowcrewcab View Post
    Right
    Solder seems to be the way to go. Now I just need to find time this weekend to brush up on my soldering skills.
    Feb 2012
    Mcalester ok
    Quote Originally Posted by NAREJEPP View Post
    Right
    It's even funner upside down in dash I use to do it I worked at a audio and alarm/remote start place but ive forgot most of it. It's been highschool days in 05 lol
    Mar 2011
    Amarillo TX
    I can imagine, I'm not exactly looking forward to it
    Definitely ready to get it done though. I got a new stereo for a deal, but am hesitant to buy or install any other replacements until I'm confident they will be safe
    Thanks again for the help
