here is the dmax need to find some of the work truck
2006 Duramax
2006 2500 6.0 work truck someday a race truck
no actually its custom built off the basis of an mpi kit. Trey fox built it originally then I basically rebuilt it for the better.
2006 Duramax
* 2004 Chevrolet CCSB Z-71 5.3L * G80, 3.73's * Black Bear Autocal 91 oct tune * Magnaflow 3" SI/SO 14" case * Airaid M.I.T. * OEM airbox with open air modification * Color matched grille & lower valence * Blackened Tail Lights * SuperBright LEDs in brake lights & reverse lights *
In the garage to be installed: 799 heads, Dyna-Tech long tube headers, Corvette servo, 2" lowering shackles, 2wd u-bolts & bumpstops
Damn Frenchy that truk looks clean.
Never seen this many clean trucks before.
Best ET 11.54@114 w 1.52 60ft
Raceweight 4905 lbs.
[QUOTE=Frenchy;484335]
the only thing you could do to this truck to make it look any better would be get a can of black tremclad and spray the hitch
