Results 1 to 10 of 17
Thread: LS6 cam into LQ9 question
    Jun 2010
    Ontario Canada home of he Beaver
    What's the lq9 compression out of te escalade 10:5?? I wonder what kind of power he would be able to pull.
    Lq9 short block
    243 heads with ls6 springs
    Ls6 2002+ cam
    Long tube headers
    Intake exhaust
    Hp tunners for tunning?
    Arizona/Utah
    Cams don't killer your gas mileage. I believe playboy has a bigggggg cam and stall in a 6.2, and gets better than most.
    Feb 2011
    cleveland
    I have a larger cam than most and my mileage was not affected with the cam. The converter killed my city driving but hwy I can get 19 with cruse set at 68mph.
    May 2010
    so cal.
    Quote Originally Posted by jbauto View Post
    Lq9 short block
    Ls6 2002+ cam
    Long tube headers
    Intake exhaust
    Stock Lq9 is 10:1. If you put a set of unmilled 243's on that would raise the compression to about 11:1. This would probably affect your gas mileage but would gain loads of torque. Probably would put down 320-340 rwhp with the set up you listed. Probably 300-320 ft. lbs. of torque also which is what counts on a daily driver.
    SOLD:1992 ECSB Silverado lm7 5.3 Swap, TR220 cam, Circle D 3200stall, CBM street tune, Schoenfeld LT's, LS1 efans, transgo hd-2 60e, custom CAI, Autometer gauges
    Best 1/8 E.T. 8.86 @ 77.8 on 275/60/15 MT ET Streets with 1.92 60 ft.
    2000 RCSB 4x4 Lq9 swap...stock except mild 4l65e....for now
    Jun 2010
    Hey guys still looking into this. The truck is on 26" whees and gas is $5.18-$5.30 a gallon here and he is not to keeen on putting a higher stall in it.
    Labour is not a prob he is a good friend ill swap it in for him
    We were thinking LS6 cam with yellow valve springs and cleaned up 243 heads and get a nelson tun on the hptunner.
    Would this yelled some good power?
    Or what do you guys recommend?
    Josh
    It'd make a very nice reliable sleeper combo. Essentially be an iron LS2
    Jun 2010
    Well the ls2 is a 400hp 400 ft lb motor.
    I think this would make a awsome daily driver and hope to pick up some gas mileage.
    Jun 2010
    just need to find some cheap 243 lol
    Ottawa, ON
    Nice meeting you yesterday Josh, think with that cam and a set of 243s will be a nice improvement, if you need anything let me know!
