Results 1 to 10 of 178
Thread: 94 Lifted Silverado 6.0/4L80e swap Build
    Get yourself a laser temp gauge and measure the actual water temp, it will be way off with the 98 sensor. BTW, WTH are you getting a 98 model Camaro water temp sensor for $8? IIRC I paid about $50 more than that for mine when I tried that.
    Jun 2009
    Caledonia, MI
    Lol I got it at napa and there was a small discount through my work I think it was listed at 18 or so but even for reg customers with no acc there is usially a little disc. I figured my gauge would be off bc the resistance differences bit my gauge was always off to bein with it would show 120 at 180
    Jun 2009
    Caledonia, MI
    Getting really close! Old harness is in, tried to crank it over and I have a few issues. The starter is jamming up against the fly wheel. When you turn the key, the starter gear shoots out and goes into the flywheel teeth, but its jamming and not releasing which is weird because the msd starter i bought is considered non shimable so it should work just fine. Other problems are NO BRAKE LIGHTS!?!?!?! I dont get that. My blinkers flash really fast. But my tail lights work. And when I turn on my heater blower motor, it clicks really fast and lights flicker. I love electrical. Not. Ill post updated pics soon. Also modified the dipstick tube so it can be used with my headers, and made a sweet ecm hold down tray.
    Silverado Z71 10" Lift COMPLETE 6.0/4L80E PRC 2.5 Ported LS6 Heads 228r Comp Cam 3200 CIRCLE D Stall LS7 Lifters ARP Bolts SLP Oil Pump and Double Timing Chain 160 T-Stat 3" SLP Loudmouth Electric Cutout Walbro 255 Pacesetter Longtubes MSD Starter NELSON Harmess NELSON Street/Strip Tuned ECM MSD Wires LS1 Throttle Body Braided Lines Spectre CAI 4.56 Gears Detroit Locker 14 bolt http://www.ls1truck.com/forums/lsx-t...wap-build.html
    Jun 2009
    Caledonia, MI
    Pic Updates
    Got a lot done tonight, most of the problems fixed. Fuel pump is hot and running, blinkers are good now and blinking normally, fan blower motor operates normally. I am pretty sure it was a big ground problem, i went through all my grounds and made sure they were clean/bare metal and it seemed to fix everything.
    Jun 2009
    Caledonia, MI
    Fire in the hole
    Fired up thee ole turd last night for the first time. Started right up and runs smooth with no surging. THANKS NELSON PERFORMANCE! I let it run for probably a minute with the open headers and noticed the oil cooler lines right at the radiator were leaking, but its not coming out of the threads, its coming out of where the lines go into the connector that threads into the radiator. So I will be buying a block off plate because I hate running those cooler lines to begin with. They always seem to leak, get kinked, and are always in the way. I believe the GM part # is 12577903 for the block off plate. I also realized that my brake booster still needs to be hooked up and has no port on the back of the motor (yet) to run a hose from the intake to the booster because my LS motor was hydroboost. So I will also have to pop out that plug on the back of the intake and replace it with a nipple that I think is GM part #12559760.
    Jun 2009
    Caledonia, MI
    Pics
    Heres some pics if anyone is looking for how I did things.
    The first pic is the green/blue wire. If you wire your coolant temp like I did, this is the signal wire to your gauge. The green wire is the old obs harness wire, the blue is part of the 3 wire (98 firebird) pigtail.
    Second pic- Coolant temp sensor with the 2 remaining wires. I had to cut nelsons 2 wire connector off (yellow and brn i think). Then you hook up the new 98 firebird wires to it. I think gray goes to yellow. and blk goes to brn. Ask me if you need help so I can 100% confirm it.
    Third Pic of the rear part of alt. I had my old OBS wire running to it for the gauge, and I have the new LS harness lead running to it as well.
    4th pic- Power junction block on firewall. I have the fuel pump running off this with some others including power from the starter lead running up to it, and my subs.
    5th pic- Just a pic of where I mounted my OBDII port. It has a really bright LED light on it, so I put it basically lined up with the 4wd shifter so its not blinding anyone when the SES light is on.
    To be continued.....(only lets you upload 5 pics at a time)
    Jun 2009
    Caledonia, MI
    6th- just a pic showing you a good spot for a tach since you will need one that goes to a higher RPM with these newer LS motors. Since the obs cluster only goes to 4500 lol.
    7th pic- This is how I am holding down my ECM on the pass wheel well. I used my old drivers side battery tray by cutting off the support bracket so its just a flat tray. THen I got a 1" wide by about 10" long stainless strap from my buddies work and welded one side of the strap to the bottom of the tray, and then the otherside I drilled a hole and welded a nut to the tray. Bent up the strap to fit snug around the ecm, and then you just snug it down.
    8th- Also had to modify the dipstick because the headers were in the way. I basically just relocated the bracket by drilling the 3 spots welds, and welding it on a different location to push it a little bit forward and keep it off the header
    no no no. The PCM would supply voltage to the transmission. I prefer that the power for the transmission comes from the brake pedal switch. Look for the lead on the brake pedal switch the has 12v with the pedal at rest and 0v when you push the pedal down. Did you see the recent posts I made for Myzterry about the wiring diagram for the transmission. I think it's terminal E on the connector that has a pink wire to it and it's supposed to have that 12v source going to it from the brake pedal.
    Jun 2009
    Caledonia, MI
    No I didnt see your post on Rays Thread so I will go look at that. I understand that I need to have the brake switch with 12v constant and then once its pressed its an open circuit so 0v, so what do i do once I find that wire and confirm that is has 12v and then 0v when brakes r applied
    Jun 2009
    Caledonia, MI
    Ok I think I get it now, all I need to do is run my brake switch wire to that terminal e on the tranny connector.. I found your post and yes it was terminal E, IF that connector is the same connector on my 4l80e.
