Good taste in trucks AND beer.
so today i decided to paint the piece in the back of the truck to make it look a little better.
tools...
masking lol...
all done
came out ok but i used the flat black and it looks faded. ill probably have to redo it with gloss or satin so it matches the carpet in the back.
i also figured out the park neutral switch FINALLY!!!! seems like the switch was in the wrong position so thats why the back up lights didnt come on or starter engage. i traced the wiring and figured out that the ground on the starter relay isnt any good. so i will have to run another ground so it will work. only issue is that the gear indicator doesnt work. any ideas guys??
got a lil delivery today..-6An fittings braided hose and fittings to connect to the trans case. also got my suspension..pro thane full polyurethane bushings! tomorrow i will hook up my new trans cooler lines. unfortunately the cooler on my truck doesn't have a screw on fitting to attach the hose so clamps it is!
Here's to new parts!
so i was able to hook up the new trans cooler today. braided hose lines were somewhat easy. just gotta be careful with the extra steel stickin out it will get ya fingers!
old leaky lines
removed clips and pulled out old lines
removed old fittings
old fittings vs. new fittings
got the new fittings screwed in
heres the trans cooler..
old lines
got the n fittings attached to the hose after some bloodshed lol
hopefully this doesnt leak..probably upgrad this later to one with the correct fittings
lines look pretty good in there
here they are connected
hopefully these things dont leak. i took off all the wiring so i couldnt fire it up..gotta figure out how to get the transmission to align on the crossmember its a PITA with only one jack. damn adjustable mounts!
I have a few questions about your harness. Im working on my old harness right now and cant find exactly where the 4x4 harness ties into the engine harness...it seems as its basically a "standalone" harness. I need to put the 4x4 harness in with my nelson harness. If you have any tips lemme know!
Silverado Z71 10" Lift COMPLETE 6.0/4L80E PRC 2.5 Ported LS6 Heads 228r Comp Cam 3200 CIRCLE D Stall LS7 Lifters ARP Bolts SLP Oil Pump and Double Timing Chain 160 T-Stat 3" SLP Loudmouth Electric Cutout Walbro 255 Pacesetter Longtubes MSD Starter NELSON Harmess NELSON Street/Strip Tuned ECM MSD Wires LS1 Throttle Body Braided Lines Spectre CAI 4.56 Gears Detroit Locker 14 bolt http://www.ls1truck.com/forums/lsx-t...wap-build.html
