Results 1 to 10 of 152
Thread: 93 1500 w/ 5.3L & 5 speed swap
    May 2010
    Galveston, Tx
    Quote Originally Posted by dustiebutt View Post
    Excellent job on your build!! I am in the middle of mine right now and have a question about the A/C....I am using the Powers A/C bracket in my '93 with stock compressor... if I bolt the stock hoses back up I get a big kink in the big suction hose.....the angle of the hard lines out of the compressor are not angled right for the Powers bracket set up......how did you fix the problem with your set up??? Did you get a big kink in your lines ?????
    He never disconnected the lines IIRC, he didn't do anything and his lines are ok.
    I'm in the same situation as you unfortunately
    95 C1500 LM7, built 4L60e, Circle D 3200, LT's, Nelson tune, open differential, 3.42, and LS1 e-fans. Tractionless
    Not sure how his A/C system works with a big kink in the hose..........I want my system to work as designed so I may try cutting the suction hard line and having it rewelded so it is rotated up and toward the passenger side to get the kink out of it..........if that works it will only cost me the price of the weld ......unless I can find a compression fitting big enough to fit the hard line..............if not about $100 in fittings from coldhose.com.............
    Quote Originally Posted by silverado_lover View Post
    '93 Chevy Sport... LS2...T56 Magnum..."Red Rider" under construction.........
    I just cut the suction hard line that comes out the back side of the compressor flush with the mounting block, drilled the block out to 5/8" stuck the hard line back in, repositioned everything for clearance and now all I have to do is get the line welded to the compressor mounting block.........easiest and cheapest and you keep your stock lines...........
    Jan 2012
    Montana
    truck came out looking good. Need a set of cal-tracs to hook it up?
    I'm waiting for the turbo build, can't ever have to much power
    88 RCLB: LS swap in progress
    00 CCLB
    03 Yukon Denali: Wife's "soccer mom mobile"
    Manchester, TN
    Quote Originally Posted by 88RCLB View Post
    Thanks. I swapped the rear shocks out for air shocks and it has helped a lot!
    Also havent posted pics of the radiator cover finished.
    91 Silverado Stepside, LT1, 4L60e, Hotcam, RRs, Headers, 52mm TB, built trans, 20" Coys, 5-7, etc...
    93 Silverado, 5.3L, 5 speed, 5-7, 20"s, GMC grille,molded pan, 454SS fogs, HIDS, etc...
    06 Silverado Crew Cab Z71, LTs, full SLP exhaust, tune, CIA, 6" lift, 35"s, DVD, etc...
    May 2010
    Galveston, Tx
    Freaking beautiful
    Rockwall, TX
    How much to make me one? That looks sooooo good
    1989 RCSS 5.3/4L60E swap
    - 224/230 .581.591 112lsa,
    - 3200 Stall
    - DJM 4/6 drop
    - Nelson Tuned
    Sep 2011
    Atlanta Ga
    Quote Originally Posted by T-Stark View Post
    +1
