Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 11 to 20 of 36
Thread: anyone ever break
  1. #11
    where can i find out how long the oem factory axle is on my 08 rcsb 2wd?
  2. #12
    Sep 2011
    I've got one out of an 03 right beside me should be the same.
  3. #13
    Quote Originally Posted by CHEVROLADE View Post
    dbrods
  4. #14
    Sep 2011
    33.562 or 33 9/16
  5. #15
    Don't try to break one. If your truck has drums, you could be losing a wheel.
    is that one from a 03' drum brakes?my 08 has drums
  7. #17
    Sep 2011
    Nope, disk. Sorry didn't realize they changed them
  8. #18
    Jan 2011
    Duluth Minnesnowta
    chevrolade if you ever get sick of looking at that truck you just pm me i will have to own it it is my favorite on here.
  9. #19
    axles are usually broken on launch, going forward, i chose to go Yukons, theyve seen over 600 and some hard launches, so did the stocks, i changed them for the simple fact i had a small seal leak ( wear ) on one side. will they hold on the new setup i doubt it, but i wont change them until one breaks
    Zach i doubt you'll have a problem just dont see your setup launching harder than a nitrous setup. unless youre spraying out the hole and cutting some serious 60 ft times.
    Simple: 408 on steroids!
    single digits coming soon!
  10. #20
    Oct 2007
    Bandera, TX
    The 99-06 axles are not the same as the 08+ just FYI.
    single digit street truck
    for build info
