I like the mod and yeah the whole world can disappear if some one wants it bad enough!
Same thing that happened to mine in SA last Feb. What handle did you buy? A rear crew cab handle?
Driver's Side Rear Door handle is what I am being told is used.
2007 RC Silverado aka ?
1998 Trans AM aka Red Dragon
Someone clear this up so I can do this over Christmas break. Mine is all sorts of jacked up and the cylinder won't accept a key anymore anyway.
yes, just buy , same side, rear door handle.
I see your truck has just plastic handles, like mine.
PN 20954815
No need to swap anything internally, it all just bolts up. No modifications required.
One thing we did: the rod that goes from the handle to the door mechanism, flip it over to the right side of the handle lever.
So, instead of inserting it into the outside of the lever, insert the rod into the inside out.
Reason: the lever on the rear handle is a little longer and I wanted to get the rod closer to it's original position.
Doing it this way, will offset it just a tad, not much, and bring it closer to the handle.
Oh ya, pop that small white bushing the rod rides on, and push it on the lever from the inside.
Nelson Performance
FastestTruckList.com
NP on Facebook
Youtube Channel
I am sending you a prizey Allen, it'll be there Monday.
It's for me, but anyways...
I lied, it will be there Friday.
Well at least they didnt basically destroy your ignition cylinder...I can barely turn my freaking key when its in the ignition.
T-RAV99 GMC | 5.3 | Skinny White Guy Tuned
