Results 1 to 10 of 12
Thread: 6l80 and smaller tires.
    Quote Originally Posted by 00Z71 View Post
    Why does this happen? Are shift points set up by rpm?
    The truck must reach two requirements for the tranny to shift. One is MPH, the second is RPM. Now, you can zero out either table there and go strictly off the other, but in this case, it doesn't matter. If you put smaller tires on, the truck is going to think it's at a higher RPM than it is, because the tires revolve faster sending more VSS pulses. The truck needs to have tire size changed in the tune to correct for these pulses. If not, it'll short shift. Rob had a few problems with this at SAR last year because his slicks were so much shorter. He was shifting 500 RPM early.
    Oct 2009
    Odessa, TX
    Weird since it is not meeting the rpm requirements... Wonder if it has to do with the speed limiter moved to calibration from GM
    99 GMC - RCSB 408 w/98mm whistle... WSLS Racing...
    Apr 2011
    East Texas
    Can you put the slicks tune on the tow haul? Were you can have your stocks on and everything be normal. Then click the tow haul on once you put the slicks on
    Pittsburgh, PA
    not correctly
    Quote Originally Posted by 1BadCC View Post
    2014 Xsport- 3.5 Eco boost
    412 Motorsports
    Okeechobee, Fl
    That would be nice if it was like that but like quik said, not correctly
    49 Ford F1
    Apr 2011
    East Texas
    Well i was hoping for the best. Guess im going to be selling my current wheels i was going to use for slicks(17s) since the tallest tire i can find for them is a 28.
