Results 1 to 10 of 26
Thread: New Cam
    Sep 2010
    McPherson KS
    Quote Originally Posted by 6.0vortecchevy View Post
    All there saying is that you can have only one or the other. You cant have both, since if you put a breather with a pcv valve the pcv valve will pull air from the breather causing a lean condition. Correct me if im wrong.
    Think that about sums it up.
    Broken Bow, OK
    Quote Originally Posted by Slammed96 View Post
    That's exactly the point I was making. You shouldn't run a vented cap AND the stock PCV system which is what Slammed96 has in his video.
    Somehow it turned into a semi-debate with everyone on the same side...haha. So, sorry for whoring up your cam thread.
