Results 1 to 10 of 11
Thread: help....need a balancer installer
    San Marcos Texas
    I always heat mine with a torch and it slips right on. Sorry I don't have a tool.
    Quote Originally Posted by GMCwantsLS1 View Post
    sorry forgot to mention i did that as well but using one of those butane torch....
    Jun 2011
    Dallas/Plano, Texas
    Don't know about overnighting, but I know dirt track racer has those installer tools over on pt.
    Derrick ; truck stolen
    im screwed,,,i had another crank bolt laying there tried it,went in good by hand...it stopped then i tried by breaker bar and it turned turned then slipped broke loose again!F***...this sucks...its still got about a little less than half an inch to line up ....shavings are coming out as well.....
    i want to get this pulley all the way lined up and go from there...ill keep messing it up i guess lol
    got the pully lined up all the way..bolt grabbed at the very end i guess..the asp didnt have to go in as far as the oem ..damm what a pita
    ill look him up thanks
    Oct 2009
    huntington indiana
    crank pulley issues are a bear, mine is hillbilly pinned and welded, and the bolt is welded to the pulley. good times with beer.
    procharger p1sc, nelson tune, 42# marine injectors, walbro 255, lt's, ory, 4" volant cat back, PerformaBuilt level 2 pro race trans, trans. cooler with e fan, 2500 stall, aem wideband, energy bushings, spohn perf. trailing and panhard rods, mb & gear alloy 22's ( ya 2 sets, im big ballin), ss brake lines, drilled & slotted rotors, bla bla bla bla bla bla bla,
    and ya it will beat a hemi.
    Ottawa, ON
    I know the GM (Kent-Moore) installer is just a M16 (I think?) threaded rod with a round socket looking thing, nut and washer, thread the rod into the crank, install the round looking socket over the rod, washer, then nut. 2 24mm wrenches to hold one nut and rotate the other on the threaded rod to push the crank pulley on. I imagine you could get some threaded rod, use an axle nut socket or something around 30mm with the same type of setup and it should work fine. Got lucky when I put mine on the LS6. Tapped it on with a deadblow enough to get a few turns of the bolt and impacted it on with no issue.
